Montag, 2. November 2026
Keine neuen Beiträge, seit Ihrem letzten Besuch am 02.11.2026 - 20:42.
Forenübersicht » 15. English Forum / Englisches Forum » 15.2. Questions & Answers » Modifying front orange repeaters to 'clear'
30 Beiträge in diesem Thema (offen) Seiten (2): (1) 2 weiter >
shiny_car ist offline shiny_car
Modifying front 'orange' repeaters to 'clear'
92 Beiträge - Neuling
shiny_car`s alternatives Ego
hello
I recently modified the front orange repeaters by removing the orange filter inside, changing them to 'clear'. I think it makes the front of the car look much nicer.
*these are the original front side repeaters on my car with their orange filters inside the housings
[imgf]http://pic20.picturetrail.com/VOL97/467659/12212732/26 9969464.jpg[/imgf]
*the original R side repeater housing, removed from the car
[imgf]http://pic20.picturetrail.com/VOL97/467659/12212732/26 9969468.jpg[/imgf]
*this is the risky step! the clear lens is glued to the main black housing; using a small (4mm) flatblade screwdriver, gently 'crack' the join around the edge by levering the screwdriver into the gap; BE CAREFUL not to use too much force because the lens plastic is brittle and is easily cracked on the front; the edges will end up quite rough, but this is no consequence; you can use a utility knife to clean the edges slightly
[imgf]http://pic20.picturetrail.com/VOL97/467659/12212732/26 9969466.jpg[/imgf]
*with the clear lens removed, you can remove the internal orange filter that is clipped into place; mine were already loose and rattling inside; clean away any debris inside the housing
269969488
*resecure the clear lens after discarding the orange filter; i would suggest a combination of superglue and silicone; my results are fairly rough, but the sides of the housing are hidden from view once refitted to the car
[imgf]http://pic20.picturetrail.com/VOL97/467659/12212732/26 9969484.jpg[/imgf]
*here are my new globes; the original H21W BAY9S globe is on the left; the new orange-tinted globes are a BA9S fitment, meaning the pins are orientated slightly differently; the middle globe is an experiment: i have sprayed one half of the glass with silver paint to further mask its presence inside the housing
[imgf]http://pic20.picturetrail.com/VOL97/467659/12212732/26 9969465.jpg[/imgf]
*end-on, you can compare the 3 globes; on the L is the original BAY9S bayonet fitment, with pins at 12 and 4 o'clock; on the R is the new BA9S orange globe, with pins at 12 and 6 o'clock; in the middle i have simply filed away one pin, allowing fitment into the car's holder
[imgf]http://pic20.picturetrail.com/VOL97/467659/12212732/26 9969491.jpg[/imgf]
*this is a comparative shot; the new modified 'clear' repeater is on the R side (L of photo), and original 'orange' one on the L side of the car (R of photo)
[imgf]http://pic20.picturetrail.com/VOL97/467659/12212732/26 9969480.jpg[/imgf]
*now here's the completed project with 2 new clear repeaters
[imgf]http://pic20.picturetrail.com/VOL97/467659/12212732/26 9969474.jpg[/imgf]
*using 21W globes, they will flash as brightly as the originals
[imgf]http://pic20.picturetrail.com/VOL97/467659/12212732/26 9970468.jpg[/imgf]
[imgf]http://pic20.picturetrail.com/VOL97/467659/12212732/26 9969471.jpg[/imgf]
[imgf]http://pic20.picturetrail.com/VOL97/467659/12212732/26 9970466.jpg[/imgf]
grosses Lachen
GT . 3.2L V6 . Q2 . Kyalami Black - Red . Eibach . KONI . ATP 19" . TOYO
Dieser Beitrag wurde 3 mal editiert, zuletzt von alfista1 am 09.08.2007 - 19:25.
Beitrag vom 09.08.2007 - 18:01
Diesen Beitrag melden   nach weiteren Posts von shiny_car suchen shiny_car`s Profil ansehen shiny_car eine E-Mail senden shiny_car eine private Nachricht senden shiny_car zu Ihren Freunden hinzufügen zum Anfang der Seite
156GT ist offline 156GT
156GT`s alternatives Ego
Nice Job grosses Lachen Good Work lachend
Beitrag vom 09.08.2007 - 18:12
Very nice, thanks to you!
Beitrag vom 09.08.2007 - 18:23
So your Australian eagle is flying clear eyed and looking bold now.
Very nice job underlining the already expressive front end even more.
grosses Lachen
Dieser Beitrag wurde 2 mal editiert, zuletzt von gt_blackbox_jtd am 09.08.2007 - 18:43.
Beitrag vom 09.08.2007 - 18:41
Cool work ! Well done lachend
Beitrag vom 09.08.2007 - 20:40
Diese Blinker will ich auch.....
Hast du super beschrieben!!! (kann das jemand für shiny übersetzen?)
Beitrag vom 09.08.2007 - 21:09
Excellent job. good job
I wonder if there's a possiblity to get black shaded front lenses. That would look even more gorgeous.
Beitrag vom 09.08.2007 - 21:11
hy shiny,
on your pictures ive seen your licences plate...very very nice !! what u payed for this special number ??
56_shiny schild
Beitrag vom 09.08.2007 - 21:12
very nice job...
wäre sowas in d-land auch erlaubt?
M.
Beitrag vom 09.08.2007 - 21:17
Blackmail`s alternatives Ego
nice one ! good job
Beitrag vom 09.08.2007 - 21:39
habs mir in gedanken auch so vorgestellt ahtte aber noch nicht zeit oder mut es auszuprobieren..
sieht wirklich super aus grosses Lachen
ich werde es evtl. auch in betracht ziehen, das merkt doch keiner in der schweizer kappenmänner..
Beitrag vom 09.08.2007 - 22:20
very nice job...
M.
Streng genommen: Nein.
Aber: Das merkt doch kein Mensch. Wenn ich nicht schon die schwarzen hätte, würde ich es auch machen.
Dieser Beitrag wurde 2 mal editiert, zuletzt von Chris am 10.08.2007 - 00:12.
Beitrag vom 09.08.2007 - 23:39
Palmi ist offline Palmi
72 Beiträge - Neuling
Palmi`s alternatives Ego
On alfista´s Request I´ll translate this detailled description to german...
@ Alfista1 Dies ist eine Übersetzung für Dich nicht für shiny car ;-)
Ich habe vor kurzem die orangen Frontblinker geändert, indem ich die orangen "Filter" entfernt habe. Ich glaube, dass die Front dadurch viel besser aussieht.
* Das sind die original Frontblinker in orange
269969464
*Der Rechte Frontblinker ausgebaut
269969468
* Nun kommt der riskante Teil! Die klare Abdeckung ist auf das schwarze Gehäuse geklebt; mit einem 4mm Schraubenzieher muss man die Klebung auf der Kante leicht abhebeln. ACHTUNG nicht zuviel Kraft aufwenden, da das plastik der Linse spröde ist und leicht einen Sprung bekommt - die seiten werden ziemlich rauh werden aber das macht nichts - das kann man später mit einem Messer wieder abschneiden
269969466
* Wenn die Linse ab ist, kann man den orangen Filter der in die Linse "geclipst" ist herausnehmen - Meine waren bereits lose und haben drinnen geklappert - entfernt jeden Grat im Gehäuse.
269969488
Klebt die Linse wieder auf das Gehäuse (Ich schlage eine Kombination von Superkleber und Silikon vor) Mein Ergebnis ist ziemlich rauh aber das sieht man nicht, wenn der Blinker wieder eingebaut ist.
269969484
* Das sind meine neuen Birnchen - das originale H21W BAY9S ist links, das neue orange ist ein BA9S d.h. die pins sind anders ausgerichtet - das mittlere ist ein experiment: Ich hab eine hälfte silber besprüht, damit es nicht so auffällt im eingebautem Zustand.
269969465
*Hier könnt Ihr die 3 Birnchen vergleichen: links ist das originale mit Pin ausrichtung 12Uhr und 4 Uhr, rechts ist das neue orange mit Ausrichtung 12 Uhr und 6Uhr in der Mitte habe ich einfach einen Pin weggeschliffen, dass die Birne reinpasst in die Halterung.
269969491
*Dies ist ein Vergleichsbild; Der neue angepasste Blinker rechts (links am Foto) und der original orange Blinker links (rechte Seite am Foto).
269969480
*Und Hier das Projektresultat mit beiden Blinkern angepasst
269969474
*21W Birnen leuchten genau so hell wie die Originalen
269970468
269970466
english original by shiny car
sollte sinngemäß alle Schritte erklären..
LG / Regards,
Palmi
Dieser Beitrag wurde 1 mal editiert, zuletzt von Chris am 10.08.2007 - 00:11.
Beitrag vom 10.08.2007 - 00:05
Diesen Beitrag melden   nach weiteren Posts von Palmi suchen Palmi`s Profil ansehen Palmi eine private Nachricht senden Palmi zu Ihren Freunden hinzufügen zum Anfang der Seite
thank you everyone. I hope it has given you a good idea. grosses Lachen
@ Palmi: thank you for translating.
@ Landmatrose: I bought the licence plate from an investor, and paid AUS$1250; this is a once-off fee (no annual fee) in Victoria, Australia; I am very happy with it; I added the '.' between the ALFA and GT using self-adhesive reflector tape
@ wasserloeslich: I agree with Chris; you would not know it was a modification unless you were an Alfisti
smile
Beitrag vom 10.08.2007 - 02:20
ilmaz ist offline ilmaz
ilmaz`s alternatives Ego
aber ob man das wieder dicht bekommt???
ALOAH aus der schönen Pfalz!!
Beitrag vom 10.08.2007 - 12:43
Es ist / sind gerade 0 registrierte(r) Benutzer und 840 Gäste online. Neuester Benutzer: Feyzo
Seite in 0.04030 Sekunden generiert
