Mittwoch, 17. Juni 2026
Keine neuen Beiträge, seit Ihrem letzten Besuch am 17.06.2026 - 20:10.
Forenübersicht » 5. Autowelt » 5.1. Alfa Romeo » Racer X Design Alfa Romeo GTV Evoluzione
http://fuksworld.blogspot.com/2007/11/racer-x-desi...o-gtv.h tml
The design is the work of Reuben Zammit and was aimed to incorporate the classic looks of the original Alfa Romeo GTV of the late 70?s, together with a more menacing muscle car touch.
The car was built by hand using only sheet metal by Jean Paul Pisani, and using a scrapped 1979 GTV as a base car. Both the front end and the back end were completely cut off and re-built from scratch, the track was widened by 8? on the front and 9? on the back, using one off wheels designed in-house!
The drive train was replaced by a 3.0 V6 24v last generation Alfa Unit, giving the car a more suitable power output. Brakes were also up rated to 4 pot Brembo calipers and 300mm vented discs, so were the suspension system and chassis in general.
43_racer-x-design-alfa-romeo-gtv-evoluzione-2007-6
70_racer-x-design-alfa-romeo-gtv-evoluzione-2007-7
72_racer-x-design-alfa-romeo-gtv-evoluzione-2007-8
82_racer-x-design-alfa-romeo-gtv-evoluzione-2007-9
Dieser Beitrag wurde 2 mal editiert, zuletzt von wasserloeslich am 17.03.2008 - 17:40.
Beitrag vom 17.03.2008 - 17:39
Ueberrascht Ueberrascht Ueberrascht Hat schon was, aber original gefällt mir der GTV6 besser lachend
Beitrag vom 17.03.2008 - 17:45
Bischen zu übertrieben, aber von vorne recht schick grosses Lachen
Beitrag vom 17.03.2008 - 17:58
Es ist / sind gerade 0 registrierte(r) Benutzer und 398 Gäste online. Neuester Benutzer: Sek1966
Bikester (35), Chris1706 (48), Dezimus (37), MadMax70 (56)
Seite in 0.03190 Sekunden generiert
